When starting my '02 ZX-6R with a cold engine using the choke, it's revving at different RPMs, and I haven't been able to identify any conditions or reasons. Here's what's happening:
(1) revs about 2800 RPM and stays there until the temp gauge starts reading, then I ease off the choke - as I ease off the choke the RPMs increase initially then slow down to idle - there is a consistent point in the choke lever position that produces a temporary RPM increase a I move the lever past it
(2) revs about 2800 RPM until just before the temp gauge starts reading then races up 4100 RPM, at which point I ease off the choke
(3) revs up to about 4100 RPM within a few seconds of starting, I ease off the choke a little to bring it back to about 2800 RPM where it stays until the temp gauge starts reading, then I ease off the rest of the way
The bike sounds like it wants to idle at 2800 RPM on choke, and about half the time it does not run up to 4100 RPM, so it seems like the high revs are not normal.
I've checked the choke cable for snags and burrs - nothing. It did not do it at the shop (of course...), so they have no suggestions.
Does anyone else experience this? What RPM are you running at while on choke? I ease off the choke when the temp gauge starts reading (it starts at 104, and I ease off by 106-109 or so) - how long do y'all keep it choked before easing off? I'm in the city, so I need it to be warmed up before I take off, otherwise I sit at a stop light 30 yards away before the engine is warm enough to be happy.
Thanks.
Dave H
SF :: CA :: USA
