1 - 20 of 27 Posts
All prices include shipping in US.
-radiator with fan in good shape, Not bent, no broken mounting tabs, no leaks, no repairs. $225
-headlight housing, the 2 top mount tabs have been fiberglassed, Someone hacked up the harness, I do not have the 2 cups for the back of headlight, and the lenses are dirty on inside of headlight. $120
-High mount micron exhaust, Can has small ding on top, Some rash on tip, also a little rash on midpipe. The can body is 11 1/2 long. overall length of can is 16 inches. $75
-ram air stay no damage $80
-mirror stay bracket $50
-Straight rear rim $75
-Used 56 tooth 520 pitch thrust company sprocket $45
-new 60 tooth 520 pitch thrust sprocket $75
-wire harness for the coils only $13
-Rectifier $35
-fuse box $20
-Front axle with spacers $18
-Left handlebar switch assembly (some light sctarhes on top) $19
-Lower triple tree with bearings $49
-rear caliper NO pads $23
-black front fender no cracks or repairs $35
-Silver front fender has crack that was repaired and missing a small junk (damaged is on side of fender, it can still be mounted with no problems) $19
-Front brake reservoir $18
-battery tray and undertray ( undertray has a piece cut of the side) $20
-swingarm bolt $18
-radiator overflow bottle $12
-Cut down windscreen (stickers all over it) $13
-rear rotor $22
-The 4 subrame bolts and nuts $9
-stock air filter $12
-shifter side heel plate $9
-Rubber seal for ram air $9
-Rubber seal for ram air with screen $12
-left side passenger rear set SOLD
-lowering links SOLD
-swingarm SOLD
-Upper triple tree SOLD
-front calipers NO pads SOLD
-rear shock SOLD
-both mirrors SOLD
-cushdrive SOLD
-Rear seat SOLD
-ignition system SOLD
-straight front rim SOLD
send me email address for pictures. Dan
Hey, will you take $25 for these?
-battery tray with seat lock NO key $19
-seat latch with cable $12
Yes i will do $25 shipped for both but the battery tray no longer has the seat lock in it ( I just used it for my bike) If you want them pm me for paypal address.
do you have any pics of the yoshi? ill pick up the yoshi if you still have it. LMK, Thanks.
Discussion Starter · #14 · (Edited)
parts update
-Rectifier $35
-fuse box $20
-swingarm bolt $18
-rear rotor $22
-swingarm SOLD
-rear shock SOLD
-both mirrors SOLD
-cushdrive SOLD
-Rear seat SOLD
1 - 20 of 27 Posts
