1 - 20 of 23 Posts
At the mileage you are currently at, you should continue to use NON-synthetic (that should be the stock grade). You don't have to use the factory oil when you change. You can use any quality oil that you find in auto part stores. Just make sure to stay within the appropriate viscosity parameters.
I would recommend just going to an Advance Auto Parts or Auto Zone and get it from there. You might have to have them order it for you, but it will be cheaper than ordering online since you won't have to pay any shipping charges. I would recommend doing the same for your filter. They will get it for ya.
Im breaking my new blue 636 in and I went a little higher in mileage then I wanted to before changing the oil, but I just couldn't pry myself off the damn thing. I'm a little under 400 miles but I just read the break in forums and now I want to change the oil and filter asap. I was wondering what kind of oil comes stock in the 03 636rs and if I should replace the used stuff with the factory oil, or should I use a better non-synthetic oil (any suggestions on oil & filter type).
Fellow '03 rider (who changes his ZX-6R for new one annually in order to have the latest and greatest) recommended me Motul oils, which should work better with Kawi's gearbox than other brands.
+37cc
__
There's no substitute for cubic inches...
Last time I checked, Motul makes Kawachem, but hey.... what do I know? As for getting oil for cheap...... don't skimp out on the "life-blood" of the engine. If you want cheap, just go get some Kawachem which I think 2.50 to 2.99 a quart and your filter do it to it. That's just my 2 cents worth.
Kelsey
I threw BelRay EXL 10-40 in mine today with a new filter. I've had good results with it in the past, so why not. I will be switching to full synth at around 2,500 miles I think though.
When I was racing my '96 6R, I used Bel-Ray full synthetic, can't say enough about that stuff. That motor was abused big time, and never had ANY problems out of it. Two thumbs up for Bel-Ray!!
Kelsey
swjohnsey..... no problem areas on that bike for the street (except for the suspension, but that is another story). As for the motor, I ran it hard and did routine maintenance and never had a problem, and not to mention I did not skimp out on cheap motor oil, I only used Bel-Ray in it. As for my new '03, I haven't decided what brand of synthetic I am going to run, probably Silkolene (because they have contingency). I still have a set of Attack rearsets that will fit on your '95 if you are interested.
Kelsey
Personally I do NOT like FRAM. I like to get my filter from kawasaki. They are not even $10 form the dealsership. But If I would get one from an autostore it would be an STP filter, available at autozone among others. And for your first oil Motul 3000 10w40 is a good oil.
Thank God for Guardian Angels... Especially This One!
Originally posted by TheManZX6R
yeah I know to use non-synthetic but I was just wondering if anybody had a recomendation for a good type of oil and filter that they trust.
Breaking in I use Mobil (non-synthetic) 10w40. I used a FRAM oil filter for my first oil change, but not anymore. Speaking to others as well as my Kawasaki dealer, FRAM filters are low in quality. You can find other posts as to what other brands to use, but I now buy mine from my dealership. $8 more, but better safe than sorry.
1 - 20 of 23 Posts
