1 - 2 of 2 Posts
What a peice of crap, why couldnt they just weld a bracket onto the can and bolt to that like everyone else instead of this clamp that has now warped from heat and become excessivly loose and has no adjustment, except to bend it. Now my can is all scratched up and after setting down a wheelie the other night the back half of the exhaust comes detached scratching off some paint on the inside of my ferring. Thats just cheap =/
· Premium Member
its a bug Kawi is aware of, they are working on a fix so I'd expect a recall before too long.
The design actually is not back, its designed so you can take that pipe off without doing any welding, but from what I've heard, the issue is the foam-like pad they used, it changes size under heat and then the can gets loose.
1 - 2 of 2 Posts
