Just adjusted my rear shock sag and put the calipers to use to measure a few things that might help to speed up the adjustment process for others .. so FYI
Each collar is 4mm or 8mm for the two (adjuster and lock).
Each thread (center groove to center groove) is approximately 1.5mm.
Each full turn of the adjustment collar is one thread or about 1.5mm.
For my weight I set my rear sag at 22.5mm from top of spring to top of threads which is equal to 14.5mm of threads only or about 10 threads.
