will 04 front rotors work on a 06 636
Banned
Yes BUT you will need 4 10mm caliper spacers. P.M me; I had some made already. You will also need 4 10mm longer caliper bolts.
Wrong!! They 04 rotors will fit the wheels, but will be to short. The 05-06 forts are designed for a 300mm rotors. Were the 04 rotors are 280. If you use the spacers it will push the calipers our even farther. Now if you were putting 05-06 rotors onto an 04 then you would be find. As the 04 forks are designed for 280mm rotors. So in short you can not swap the 04 rotors onto the 05-06 forks.
Banned
DOH! I guess I should read more carefully before replying. You're absolutely right. 05-06 rotors will work on 03-04 with the 10mm spacers. Why would you want 03-04 rotors on an 06 anyway? They are smaller and not as trick looking. Plus the larger the rotor, the better and less effort with the braking.
