Hi there, I have a 04 ZX-10r but recently I had a problem of my headlight and signal light not working at all. Normally when the ignition is started the low beam will be activated. But mine doesn't activate at all. Even i switch to high beam and turn signals non of them works. But other functions works so far (for those i had tested).
I had tried checking the fuse (all seems fine) as well as get another relay box (Junction box) to test and its still the same. However I had found out there were clicking sounds (like electricity) when the engine is started from the relay box (not sure its normal).
Anyone here had experience same issue or know how to rectify it? (its a bad thing to ride w/o signal and headlight =()
Thnx in advance...
