my way is a little different. Its wired up to a stand alone switch , so if your just sitting in a parking lot pimpin' it, put them up to get some looks haha..
Heres how I did my City Lights.
Tools Required
Normal hex keys
Drill
1/2 inch drill bit
Wire cutter
Wire Stripper
Parts Required:
(2) 194 Sockets (Ford, GM cars) Available at AutoZone, PepBoys, Advance, etc.
(1) Roll of 14-16 Gauge Wire, any color.
(2) 194 Bulbs, come in almost every Kawi color, red, green, blue, etc
Various Termials
(1) Toggle Switch (w/LED light for coolness)
Step 1:
Take off both panels that you would take off to replace the headlight bulbs.
Shown Here:
Step 2: After you take off both panels, this is what you will see, keep in mind i took these pics AFTER install. So the bulbs are already installed.
Shown Here:
Step 3: Locate this part where you will need to drill the hole. It looks like a 4MM bolt head sticking out with a circle surrounding it.
Step 4: Take a 1/2 Drill bit and drill SLOWLY!!! through this to open it up. TIP: Do not push hard, its very soft plastic the bit will do its job with ease. If you push too hard u can go right through and hit the headlight housing itself and you will make a nice mark in it. The 194 socket is a little bigger than 1/2 So just round it out more, open up the hole untill the 194 bulb socket fits in tightly.
The hole should look similar to this. Make sure u clean up the plastic shaving you dont want that inside your headlight.
Shown here:
Step 5: Now look at the sockets, They have 2 wires coming off, find out which one is power and which is ground. Just touch the bare wires to the battery and see which ones on either side of the battery illuminate the bulb.
Step 6: Run 2 wires from the battery 1 power and 1 ground, make sure you have enough slack to reach the switch wherever you decide to mount it.
Step 7: Drill 1/2 hole in the gauge support bracket. Install the switch, tighten it down.
Step 8: Now splice together the POWER wire coming off the right bulb socket with the power wire coming off the left side bulb. Then connect those wires to the ACC terminal off the switch.
Step 9: Pick up the GROUND wire off the battery which you ran in Step 6. Now take both GROUND wires coming off the bulb sockets (usually black) and splice them together then connect it to the GROUND terminal off the switch.
Step 10: Now pick up the POWER wire off the battery which you ran in Step 6. And connect it right to the POWER terminal off the switch. You might want to use a fuse, but which this small amount of power its not necessary.
Step 11: Check to see if the bulbs work
Step 12: Put the covers back on
ENJOY
Hope this directions where good enough for everyone. PM me if you need additional help.
