I will check the lines again, but it seems like a vacuum problem would be able to run at idle for more than 30 minutes.Could it be a vacuum problem with the fuel tank? Maybe check for leaks and blow out the breather holes.
Above statement does not sound like it is starving for fuel.I will check the lines again, but it seems like a vacuum problem would be able to run at idle for more than 30 minutes.
I can also open it WOT with no hesitation or fuel delivery issues.
Yea, which led me to my suspicions of overheating something and after turning it off, it cools enough to run again.Fuel delivery issue would not allow above statement.
yea, im waiting for nevada and zx6rnewbie to chime in. I forgot to open the gas cap...will do that on the way home tonight.When it cuts out next time, open the fuel cap and see if there is a strong vacuum. My general bike knowledge tells me there should be a valve that lets air in as fuel gets used, if this fails (or pipes kinked, which you checked) then the vacuum will build to a point where the fuel will be starved.
You should be able to check this valve by blowing through it.
I'm sure the big boys will be able to shed more light on the problem.
Did you have a stock exhaust?I agree. Swap the ecu. That fixed mine
I've read posts of bike with bad ecu's getting hot after 20 minutes and acting a fool. Try swapping a known good ecu before you go buying a new one if possible
Looks like I'm going down this route. I've tried meeting up with some people "near" me with zx6rs, but can't get schedules worked out.I agree. Swap the ecu. That fixed mine
sent payment for an 05 ECU with no known issues, will update after installationyeh, it does sound like the ECU.
well, either USPS sucks or my building doorman sucks. Either way, I don't have the new ECU. I took off my midpipe today to see if the exhaust was contributing to ECU problems--it wasn't. Still cutting out.sent payment for an 05 ECU with no known issues, will update after installation
