1 - 20 of 498 Posts
05/06 ZX636 ZX6R speedo upgrade
Hello everyone.
A while ago there was a big discussion on how to fit a P7 style ZX6 speedo onto an older model bike (typically the 05/06 C1H model).
The main reason for doing this was to have the nice white dial easily readable clocks instead of the quite trick but less clear LCD type.
Well the long and short of it was that you could replace the speedo (indeed the mounting bolts are exactly the same for both models) so long as you made up an adapter (because the speedo used a different connector on the new model). However you had to put up with an annoying flashing warning light caused by no ECU communication to the clocks. The only solution at the time was to tape over the light, but then you wouldn't have the benefit of any real warnings.
At long last I've got around to reverse engineering the communication signal between a P7 ECU and a P7 speedo. The idea is we fit a little micro chip circuit to fool the new speedo and make it all work perfectly on an 05 ZX636. In fact, not only does the warning light behave, but we can also make the gear indicator work properly (ie make a TRE type gadget) too.
I don't expect this to be much use to most folks, but I wanted to put the info into the public domain as its apparently not known. You would need to be an electronics engineer to make use of this stuff.
OK, here we go with part1. The signals:
The speedo ECU comms line has a built in pull-up resistor to 10v so to inject a signal we need an open collector drive.
The comms line is normally HI (9.8v or so)
Data is sent in three packets at 10ms period between the start of each data byte.
The data signal is repeated at a period of 80ms (or roughly 60ms from the end of one packet to the start of the next).
If the data is interrupted, then after a few seconds the speedo will report a FI error and do the flashy red light (LED) thing, so we need to keep the data packets going continuously.
The data starts only when the ignition is turned on.
The three packets of data are all serial 8 bits plus one start bit (lo). The period of each bit is 64us.
(The following data is written as if it were a timing diagram)
1st gear ...10100000001..(10ms)..10000000001..(10ms)..10100000001..(60ms)..
2nd gear ...10010000001..(10ms)..10000000001..(10ms)..10010000001..(60ms)..
3rd gear ...10110000001..(10ms)..10000000001..(10ms)..10110000001..(60ms)..
4th gear ...10001000001..(10ms)..10000000001..(10ms)..10001000001..(60ms)..
5th gear ...10101000001..(10ms)..10000000001..(10ms)..10101000001..(60ms)..
6th gear ...10011000001..(10ms)..10000000001..(10ms)..10011000001..(60ms)..
So for 1st gear, if we monitor the speedo to ECU signal line (on a P7 speedo to P7 ECU of course) then we see the signal go to 0v for 64us then 9.8v for 64us then 0v for 448us then back to 9.8v
There is then a gap of 10ms (less 576us) to the middle packet which is a null frame: 0v for 576us
After another gap of 10ms (less 576us) the first data byte is repeated.
The data line is then inactive (still at 9.8v) for around 60ms until the whole thing is repeated.
(In the data sequence shown, dots represent where the data line is at a steady 9.8v level)
The speedo uses these data packets to continually verify the comms to the ECU, but of course these also represent what gear we are in.
So long as any of these 3 byte data packets are being sent then the FI/red LED will not be activated due to comms fail.
If the bike is in neutral then no gear is shown on the LCD part of the speedo.
If the bike is in gear then the LCD segment shows gear 1-6 depending on what data packets are being sent on the ECU comms line.
We are now in a position to make our own automatic gear indicator using engine RPM and wheel tacho signal. This is done by dividing the engine RPM count by the wheel tacho count. Both these signals already go to the speedo for displaying speed and revs.
OK, so I'll follow this up with a part2: cheap hardware to do all the signal controls.
Finally part3: this will be the software to program into a PIC micro.
Cheers
Extr400
If it's of any help, Gipro makes a product that extracts gear information from the 03-06 ecu trough diagnostic socket. They state it's a ecu calculated information (the ecu does know the gear) but then again diagnostic socket might only feed tacho and speed signals through.
If you come up for a circuit your planning at least I'm glad. Kit ecus don't have gear information, so all your hard work would be unuseful for at least me...
Keep up the good work! :)
sweet, but being i run the kit ecu as well...OOPS
dont mind the little F1, being mine is taped over, as long as the tach works and with the speedohealer speed and water tmep thats all i really need anyways.
Extr400, you really need to post MORE OFTEN.
good info man.
i had read of some guys yanking the speedo sensor and getting a fault. did a lil research and saw it DOES log that, flag the bit, store in the fualt bit registry and dispatch a FI light code.
i was unaware it's a 10V pullup. thought it was 5V or 12.. lol
i had read from someone else ( an embedded electronics engineer) that theres a way to fake the ECU on the 12-R to "bypass" the speed limiter. it utilized the pulse count off the tach to drive the ECU's input and satisfy the bit detection. i think he ran it thru some NPNs or an op amp for some voltage changes. can't remember if maybe one signal was TTL and the other wasn't?
hafta look it up.
good shit. reps.
Discussion Starter #6
05/06 Clocks upgrade to P7 - nearly there!!!
OK,
So been busy with a micro development kit all weekend and have now completed the first part of the software to quench the FI light and get the gear info working in the P7 clocks.
At the moment have a little test program running to prove my kid-on ECU communication to the speedo. It cycles through all the gear codes so the display can be verified.
Good news is everything working good. No FI error or red LED. Gear selection readout is stable and glitch free. Have posted a picture here. This is such a super trick upgrade :)
Have to write some more code next to use the revs and speed to calculate the gear. Also need to rescale the speed pulse as the gearbox ratios are different for the new clocks.
Have based the electronics on a cheap Microchip development kit / programmer, but I think it will be possible to use a home made programmer (like Pony Prog) which only costs $10 to build.
sick im watchin this now looks good and awesome work
hell yeah if you can make an add on for the speedo, gear indicator and f1 light to stay off i am sold!
ready for the test kit anytime you are....
u make a plug and play and im sold! i love those tach's
i do have a question though...evenutally i may regear my bike for shits and giggles how much would that be affected or would usin a speedo healer still work?
also...the redline on that tach, anyway to make it so that it shows the redline of the 636? or at least have hte shift light option still?
Discussion Starter #12
Hi Lemmon1-
Lets see how this thing turns out. If I get enough interest I may design a custom PCB to act as a plug adapter + micro board. It only need be slightly bigger than the connector outline.
Had thought of the gearing issue: could provide an option for a 1xtooth smaller front sprocket. Anything more complex in terms of gear ratio can easily be catered for by options in the software.
Remember this is effectively a speedo healer as well, so you don't need anything else.
Had not thought of the tacho red line, but the shift light will work ok. Will have a think about this.
Cheers
Extr400
Great job. As an Electrical Engineer myself, I understand what youre doing. I just dont have the time / patients to accomplish it! Congrats!
For the record I'm a Mechanical Engineer and have no idea what he's talking about!
:D
haha
After the first post i thought he was just a smart douche that wanted to sound cool by throwing out all this technical verbiage. But now that i see you have something i like, you're cool. I'm patiently waiting in line for one.
thats kool...im pretty sure on the redline part its probably painted on from the factory so not tooooo worried bout that...as for gearing i probably wont do anymore then a +2 on the rear just for a lil help, maybe...to be honest im just more interested in the plug and play deal more then the rest of it
Nice work!
If it's not of hard work, I wish you'll save the code that does not heal the speedo. As 03/04 and 07/08 kawis use same speedo input no healing is needed.
And I'm just throwing this: if you run other gearing than stock but catch the rpm and speed input (speedo will be off) won't it calculate the gear right? And if you would use something like a speedohealer AFTER the gear has been calculated, you would also have correct speed on the speedo? So that would address the problem with gearind changes...
And I have to add, are you able to code an interrupting input on the circuit?
This box will eliminate the FI function all together which isn't nice... But if you could make an input that seizes the box from transmitting on positive input (the old fi light signal of course) then it would start to flash the FI light when there's a real problem...
Discussion Starter #20
Ok, time for another update.
Now have the speed signal conversion working. I'm testing with the old and new speedo but the new clock has my circuit doing the conversion.
Scale factor is to divide frequency by 4.2211 (hmm, if your interested - the service manual for the P7 clocks appears to give the wrong tacho test info). In fact my software allows almost any scale factor with a very high degree of accuracy.
At the moment, the scale factor number is hard coded in (meaning you can't change it) but am thinking of having an external push button to allow an adjustment function. This would make it easy to cope with any gearing change without having to go away and reprogram the micro.
Out of interest I put a signal into the tacho pin of each speedo. Its a bit rubbish that both read on the hi side. The C1H is 6% rpm too fast and P7 reads 2.5% rpm too fast (the input signal was 13,140 rpm) - anyone else noticed this? It does compound the problem of the shift light being triggered at 14k on the old speedo and 15k on the new one. Have just about exhausted all the functions of the tiny micro that I chose for this project but there may be a bit left to do a tacho healer too!
Still have to calculate the gear from the speed and tacho signals and then I can feed this into the bit that sends the digital code to the clocks ECU pin. Incidentally, this is independent of any final drive gearing, because it uses the signals directly from the engine pick-up (and before being re-scaled). So if you change sprockets the gear indicator will still read correctly.
If anyone wants to get ahead of the game and build one of these, you could do worse than order yourself a pickit2 from Microchip (available direct or through Digikey.com in the USA or Farnell.co.uk here at home. There are also copy versions on ebay). You will also need the specific micro which is a PIC12F683. Will post a zip file of the circuit board and software files soon as its all tested.
One final note, its true that if you feed a scaled down speed signal into the ECU itself, then you will proportionately INCREASE any speed limiting function within the ECU. However this may also affect the ignition mapping so care must be taken. Personally I'm only using the circuit described here to alter the signals to the clocks - not to the ECU as well.
Extr400
1 - 20 of 498 Posts
