what’s up I’m a new member here and have a question concerning some wiring problems I’m having. I’ve researched for hours with no luck to my issue. I have a 2006 636 and i have wire that I can’t figure out where it connects to. It comes from the atmospheric pressure sensors but I can find where it’s suppose to be connected to. It’s a brown and black wire and a ground black wire. Pics below appreciate the help
Discussion Starter #4
wow infeel
Those wires are for your horn, not sure its related to your vacuum syn issue?
Wow I feel dumb thank you. I doubt it’s related also. I’ve tried new spark plugs and it’s been tuned by dyno. Some have suggested it’s a vacuum leak which I’ll try to find by spraying some maf cleaner, see if I get a jump in idle. I also went ahead and ordered new coils see if that’s helps. I’m thinking I’ll do the clean air mod while I’m taking everything apart. Also, I’ve noticed I have a oil leak from my valve cover gasket so I’ll knock that out also. I’ll keep y’all posted.
