How's he going to get it there? If he has a trailer or a pick up, I agree.
Buy an effin' multimeter! Test that battery, you should be getting 12.8 or more. At 11.3 (?) volts the battery will still turn the starter, but not start the bike (terminal voltage). Oh, and if you do get it started, here are some simple charging system guidelines I posted for someone else in a different forum:
While the bike is running, if you're getting a reading past 15 volts, your regulator is shot. If you hold the multimeter to your battery and it slowly drains in power, your stator is bad. If you charge a battery and you get less than a couple starts off of it before you can't start your bike anymore, you've got a bad battery.
