Does anybody know if a tail from a 2006 zx10 will work with a 2006 zx6r? I would like to change the tail to a zx10 to get rear blinkers on the tail like the zx10.
It won't bolt right up, obviously. It all depends on how friendly you are with the welder. Probably not too friendly, since you're asking this question in the first place. So no, it won't fit. Subframe would have to be modified with new mounting points and the exhaust would most likely have to be re-routed entirely. If you can figure out a way to eliminate the undertail muffler setup, then it would be much easier to replace the entire tail section including swapping the subframes.
