1 - 16 of 16 Posts
I've got an 06 zx6r. I just bought a set of 07 calipers to put on. I want to get galfer stainless lines but wasnt sure if I should order the lines for an 06 or for an 07. Thanks
You can run 05-06 lines but are longer and have more slack. Just buy a set of 07-08 lines and you wont have a problems but like BUG said it really doesnt matter too much either one will work!
I was actually thinking more of my bike with 07 calipers and set-up on...
Do it, you wont regret it. Direct bolt on and they are awesome calipers compared to the Tokico POS ones that are on there now.
You can use either the stock replacement lines for your bike or the 07 specific ones. The stock replacement (aka galfer braided) will be about an inch or so longer due to location of the mount on the Tocico calipers, the middle of the brake cups. The 07 Nissin calipers, the banjo mount is at the top of the caliper.
well I've got 10mm longer bolts and 10mm spacers for the 05+ discs, just thought the mountings etc were different for the 07+ calipers. As for the lines I know plenty of places that make them up to fit, so that part doesn't matter.
Now just to see if the 07 radial master will fit the bar..
ahh how i love my nissins.....yeah the 05/06 lines work just fine but as stated are a bit long. nothing a zip tie cant fix
06/07 masters are the same and will just bolt right on any 05/06 bike
did they change the masters in 06? I thought it was 07??
Either way, that's a bit of a better one imo cos a) has another bleed valve on the top (did the 05+?) and is radial (?), and it's newer. They aren't going to replace a good thing with a crappy thing. They'll replace a good thing with an awesome thing, so yup, should work better in theory. It'll be a bigger jump for me than you, but still should be beneficial
I would love to see the finished product if you decide to fit the nissin calipers... I'm very interested in doing it myself. along with the swingarm swap.
hey, keep watchin my space man..
The motor has had some head work done which is just about finished up. Now it goes faster, I'm quite keen to stop it faster. And since it had chronic brake fade under the hammer on the track, kinda interested at my options, bang for buck. This could be the goer
I have heard nothing but good things about the Nissins. My Tokicos are good but have lost there touch IMO and Im wanting something more, with some good pads and braided lines the Nissins should more than satisfy what you are looking for in the stopping department.
1 - 16 of 16 Posts
