I'm installing an 07 radial master cylinder on my 03 zx6r. It appears that the brake line fitting coming off the master cylinder will interfere with the throttle cables. Can the throttle cable assembly be rotated to accomodate with no ill effects?
i was thinking of such because last night i loosened the two screws that hold the two halves of the throttle cable housing together and lightly tried to rotate it with no success. a lot of people have put the later MC on the 03-04 so someone has to have some input on what they did.If I remember correct, throttle assembly is locked to the handlebar with a pin, so you won't have very much room for movement.
That would raise the lever to an unacceptable location for comfort as well as conflicting with the upper fairing stay. My new brake lines should be here today or tomorrow and I will try to sort it out.Try to move / rotate the master cylinder a bit? Throttle housing should be the same on all models.
If you pull it apart I beleive there is a plastic pin in the housing that fits into the clip on. You should be able to break this pin off if you want to be able to rotate it a little bit more. It should still fit snugly after you tighten up the screws again.If I remember correct, throttle assembly is locked to the handlebar with a pin, so you won't have very much room for movement.
there is a pin on the throttle cable housing that inserts into a hole in the clipon. i'm going to file down the pin to rotate the housing to where i need it. i'll report back when/if everything still functions properly upon completion.If you pull it apart I beleive there is a plastic pin in the housing that fits into the clip on. You should be able to break this pin off if you want to be able to rotate it a little bit more. It should still fit snugly after you tighten up the screws again.
I did this on my suzuki and haven't had any problems.
AHAH! I was thinking totally inside the box, just gonna hack it off. Thanks for this suggestion!!!yea what your gonna have to do it find a drill bit that is around the same size as the nob on the twist grip and drill a new hole. i had to do the same to fit my brembo master on my bike. you also usually need to do the same to mock up race body work. especially if you have clip-ons.
