ok.. here is the deal... i have a set of 07 zx6r calipers, master cyclinder, lines, reservoir, levers, and rotors lined up for my bike.......all for 600 bucks... i know the calipers will fit my 04 636... now
will the rotors fit as well?? or do i have to manufacture spacers for the rotor to fit?
im going to get the calipers/MC/lines/reservoir.... might as well get the rotors aswell if they fit....
thx in advance guys...
Your going to need to either buy or make spacers to use the rotors. I made mine out of 7/8" diameter aluminum bar stock, they are 10mm thick and have a slightly larger than 10mm hole. Any machine shop should be able to make these for fairly cheap. Your also going to need to buy 10mm longer bolts, I got mine from the hardware store, make sure they are high grade. I think the are 10x1.5 metric threads, they are a finer than normal thread.
