1 - 16 of 16 Posts
Hi guys sorry iff this has been mentioned before,ive checked the parts swap list and it says the zx6r 07/08/09 rear shock will fit my o6, is this a good swap is it worth doing, and is it easy to do as it says you have to grind a bit off the bottom to get it to fit... any help would be great..thanx guys.
the 09+ rear shock blows...why do you want to swap it?
It bolts right up and is an excellent upgrade from the 05/06 shock. You can find them quite cheap if you shop around, I picked one up for $60 shipped with less than 1,000 miles on it and used it for a while before I upgraded to an Ohlins unit.
It's a few mm longer than the 05/06 shock, and you'll want to flush up the outer fork tubes with the upper triple if you haven't already for track duty.
In addition to having high/low speed compression adjustment and being sprung much lighter (a big plus unless you're 220 lbs), the fact that the 09+ will presumably be much newer and have less miles on it will mean that it should perform much better than the tired old 05/06 shock that is probably on your bike.
And finally, the valving is much improved over the 05/06 shock.
I stand corrected...didn't realize that it was that big of an improvement over the 05/06. I have one for sale if you want it haha..
haha makes sense. Well, my offer stands..I've got one for sale
That Fighter Guy
I got an 09 shock off of ebay for $55 shipped with very low miles. Even without adjusting it I could feel the difference between it and the 05/06 shock I had adjusted. It is a little longer than the 05/06, but if anything it'll help a little with turn-in. It's a direct swap also, no modification required. It has a stiffer spring which works great for me at 215 lbs butt nekked.
That Fighter Guy
It doesn't have a stiffer spring, the 05/06 is stiffer.
The 09+ is 9.2 kg/mm and the 05/06 is 9.7 kg/mm.
Well then my 05/06 was more worn out than I thought because it was soft as shit. I had to add a ton of preload to get the sag where it needed to be. The 09 shock needed no adjustment.
x2. Plus the 09s are a little lighter from what my Ohlins guy told me.
-Cody
That Fighter Guy
Yeah my bad, I didn't look up the specs, I just went by how they felt. Either way, the 09 was well worth the $55. I've even heard people say they like the 07/08 shocks better than the 09. The biggest thing is that you get a shock that's not worn out.
Well...mine's a 2012 shock with ~200 miles...so, it's definitely not worn out. And I only weigh about 180
Discussion Starter #15
nice one guys thanx for the replies, i got a 08 rear shock,heard the 07/08/09 are exactly the same... went straight on no hassle, bike felt harder to tip into corners, but i did have everything set on fairly hard and i removed the 6mm spacer that kawi put on top of the shock so's to get my feet down a bit better as im a short arse.. so ive put the 6mm spacer back on and softened the shock a little, waiting to find out how she feels now just waiting on my new hotbodies tinted screen coming...
If anyone else needs a shock from an 09, hit me up :)
-Cody
1 - 16 of 16 Posts
