Both.....your odometer will calculate at a faster rate.....but not by that muchI have a 70 mile ride to work, after I went -1 it's now about 73/74.....How do you guys like the difference so far?Does installing a -1 sprocket mess up the odometer reading or just the speedo?
I only did about 10 or so miles on it, but so far i love it, bikes comes alive at like 5-6k now instead of around 8 or so.Both.....your odometer will calculate at a faster rate.....but not by that muchI have a 70 mile ride to work, after I went -1 it's now about 73/74.....How do you guys like the difference so far?
You put on your front sprocket backwards and your going to destroy your chain, and any aluminum sprockets within 500 miles cause it won't line up with the rear sprocket.I was told by my local Kawi dealer parts department that if I put the sprocket on backwards it tricks the speedometer pickup and they mph and mileage remains accurate.
Where's a cheap place to get a speedo heeler from?the speedohealer takes all of 5 minutes to install, if you are concerned with the speedo being off or odometer being wrong. Pick one up, they are cheap and work great. Had them on all of my bikes so far.
