1 - 2 of 2 Posts
Hi Everyone,
I recently purchased a 2011 Ninja 1000 (Ca Model). I noticed I only have a Compression Damping Adjuster on the Right Fork. There is not one on the Left Fork. There is only Preload and Rebound. These are not the big piston forks. The owner's manual says that the adjuster is located at the lower end of EACH front fork leg.
Does anyone else with a 2011 Ninja 1000 or Z1000 have the the same or different setup??
Thanks
yep, same shocking discovery here on my new '11 ninja 1000
indeed the manual (page 134) clearly states the compression damping force adjuster is located at the lower end of each front fork leg.
the left side does not have any adjuster.
the right side has the adjuster.
The service manager where I bought checked the service manual which states the adjuster is on the right side only.
what a disappointment.
1 - 2 of 2 Posts
