Hey Beard,
I purchased an used swingarm of a 2005 ZX6R and took measurements for the spacers and bracket. I created a CAD-file with these measurements and asked local machining shops for quotes. Turns out; Your kit is indeed really cheap!!
So I was thinking of buying your kit but to buy in confidence I would like to know if the measurements of my drawings compare to your conversion kit. Is it possible, in this topic or in case of confidentiallity of the design via email or PM, to compare the width of the spacers and bracket?
Everyone doing this swingarm swap uses a used swingarm which might be tweaked in the slightest and therefore the kit might not work for everyone. I checked my measurements on the swingarm and motorcycle that I'm using so I know these measurements are correct. And though a few mm difference is not a big problem, I like to know before I buy your kit.
I do not want to copy your design and have it made locally so if I could send my drawings (CAD format, SW2013) and you only verify that the kit is (near) identical I would buy your kit and know it will work.
I hope you understand my position because I read in on zx6r.com that someone had fitment issues and you even send your own swingarm to help track down the issue. Since I live in the Netherlands (Europe) this wouldn't be "ideal". And if you have my measurements you also know the kit should fit in one try.
I hope you are willing to help me out.
Greetz,
Roel
(PS. I took my measurements of the chain with the original swingarm, then swapped swingarms and aligned the chain. Next measured the distance between the swingarm and left side of the wheelhub and using the original spacers calculated the size of the spacer needed. Then I measured the swingarm's width and calculated the the right side spacers measements and the brake bracket size. So I know these numbers work for my bike with my swingarm.)
