1 - 20 of 28 Posts
I have a low mile wrecked 1999 ZX6R I am parting out. I can not confirm the mileage but am told the kid wrecked it soon after buying it. All indications are that the bike is low mile from the look of it and components.
Tank is junk, frame is junk, only fairings is the tail and it is good...motor fired right up and sounds perfect for a couple seconds..carbs are gunked up and can't keep it running. Header has a couple pretty good dents in two pipes....cheap if you can fix it. Forks are holding fluid but have not had a chance to check to see if the are straight for sure.
Pretty much what you see in the pic is what there is with the exception of what i mentioned above.
So if you need any parts hit me up.
Also have a 96 zx6r and lots of zx7r parts.
lots of parts in very good condition on this bike so hit me up with your needs.
As for the motor...I can not confirm miles but all indicators are that it is a very low miles bike...so for that reason I am open to reasonable offers on the motor.
Discussion Starter #4 (Edited)
Here are most of the parts and prices...parts are in great condition unless stated otherwise and include shipping to lower 48
Rearsets complete $65 each
Pass pegs/brackets $25 each RIGHT SOLD
Grab handles $20 each
Swingarm $50 SOLD
Rear shock $50
Shock rocker/dogbones $35
Rear caliper $30
Rear brake line $15
Rear caliper bracket $25
Rear master cyl $20
Rear subframe $95
Rear inner fender $35
Rider seat $55
Tail fairing $95
Taillight $30
CDI $125
Front calipers $40L $40R
Front rotors $60 each (5mm)
Rear wheel bare $75
Front wheel bare $100
Wiring harness less relays/cdi $40 SOLD
Rad overflow tank $25
Chain guard $25
Swingarm bolt $20
Frt axle $20
Rr axle $20
Right clipon switch $50
Right clipon $40
Voltage reg/rectifier $50
Rad hoses $30
Clutch lever/perch $35
Brake Lever/perch $35
Air box $50
Speedo pickup $25
Coil pak $40 each
Rear Turn sigs pair $30
Plug wires $50
Ram air ducts..through frame rubber ones $35 pair
Lock set $75
Motor $650 OBO SOLD
Starter
Carbs
also have forks and triple tree from another 6
gas tank with pinhole leak...otherwise clean
and more
A few other items so hit me up and let me know what you need.
Just received the swingarm. Its in great condition, Thanks for the quick shipping you were great to work with! Mike
Do you have the petcock? I need the whole assymbly from the on/off/reserve nozzle to the the hoses entering the petcock. If you have it how much? Thanks
1 - 20 of 28 Posts
