I just bought the bike and got all the carb issues sorted out. Went to take it for a ride around the neighborhood and found out it had an issue shifting. First off the shifter doesn't spring back into place, and is very hard to move at all. I was in sneakers and it felt like my toe was going to snap before it moved. When I got it shifted into first it just stays down, returning to neutral as I pull it back up with my foot. It does the same thing when I go into second as well. Then it's stuck all the way up so there's no way to get into third.
Based on what I read so far I'm going to try changing the oil tomorrow. If it persists I'm going to look into a bent shift shaft or bad return spring. Other than that is there another possible cause I may be missing?
