1 - 10 of 10 Posts
I have a 2001 zx6r and I want to know if the starter connects directly to the battery or does it go to the ignition relay? Or does someone have a simple diagram to follow?
There's probably a break in your connection to your pulsor coil on the right side of your crank case. It's probably not signaling your spark plugs WHEN to fire.
ok thanks I will pull and see . I didn’t us a filler gauge when I installed it.
Shouldn't need a feeler gauge. Says here if you have over 462 ohms or under 452 ohms of resistance in the sensor it should be replaced.
1 - 10 of 10 Posts
