Quick question how do i get the codes off my bike it's an 02
ZX6R, its running rough and sputtering in 2nd gear and higher gears... im working on cleaning the tps now hoping it will fix issue I also replaced the ecu unit as well... id like to just see what codes it gives me and start working on whatever it says
Moderator
I'm confused. 2002 ZX6R was carbed in the US. In which case, it won't generate codes.
Green is correct!
No codes for this bike.
Maybe get a service manual and see if the troubleshooting sections can help you. If not, try shouting out to this forum or the ZX-6R forum. Lots of us like this bike (ZX-600J).
Without knowing more, I would suggest a systematic approach to make sure all the following are working correct:
  • engine compression
  • valve timing & adjustments
  • wiring & ignition
  • fresh fuel supply
  • fuel pump & filter
then you get into the carbs:
  • carbs need cleaning?
  • vacuum leaks
