So heres the deal. I have a 2005 ZX6RR with a power commander, k and n filter, and a yoshi RS5 slip on. The power commander has a map set for a k and n filter and the yoshi pipe. When I am riding hard on the ninja and get it up and staying up around 10oooRPMs it sometimes cuts in and out like its hitting a flat spot. It doesnt do it all the time just once in a while. When the tank is full the bike doesnt do it, just when the bike is starting to get to about a 1/4 of a tank. Its wierd that it just started doing it. The bike has now about 3k miles on it.
Here is what I am thinking:
-Connection is loose, maybe one of the fuel injection connectors from the power commander, so when its just has enough rattle from the rpms it misses
- Air filter may be starting to get clogged enough to effect the air flow causing there to be to much gas/ air mixture
- Power Commander is getting to hot sitting where it is because of the undertail exhaust causing it to run errors
- Had bad gas in it and after filling it up still havent run all of the crap out of it yet
- The map on the power commander is giving it to much/ to little gas
What do you guys think? I am going to take up the tank tonight and check all the connections and see how the air filter is looking....
Any advice would be great!!
