appreciate JD...
My shop won't have the Dyno up for another 2 weeks. So I will try this one with the Arata. Probably will still custom map it later unless your map is the shiznit....I will email you with updates!!
Thanks again!;)
JD's map rocks, I referred to it as the "busa beater" map. Make sure you have your throttle adjusted [closed/open] correctly with the PC3 software.
