Moderhater
Is it possible to bring the idoling up to 1100 rpm because my new zx10r seem like it idols really low almost like 900 rpm at times I just want to bring it up 100 to 150 rpms more, can it be done??? and easily with out a bunch of shit being done to the bike.
When i picked my 06 zx10, the mechanic said that the idle would probably need a tweak. The idle adjustment is on the side with the shifter, its a little rubber tube with a adjustment screw at the end. Turn it right or left to raise or lower.. But check it out in the owners manuel to be sure...
Moderhater
thanks for that! I just adjusted the idioling pin/tube and put it right where I want it!!!. Have a great Turkey Day!
Yes, use the idle adjuster, should be attached to the hose in front
of the left foot peg. It should be idling around 1200 rpm.
Moderhater
Thanks man! I found it a few days ago and set it right where I want it. I appreciate the follow up. Have a Great thanksgiving!!!
