This is just a general question regarding a Z1 gas tank. There is a rubber hose coming off the bottom of the fuel pump that goes to the lowest part of the gas tank onto another nipple.
Is this just an added fuel inlet for the part lower of the tank? This isn’t the main pick up correct? I see the pump had a cylinder baffle around it which leads me to believe the main pickup goes in through the actual pump somewhere..... thanks and lemme know if you need more underdog what I am asking 😛
