Hello all I'm new to this site I'm getting ready to check the valve clearance on my 08 zzr 600 with 10000 miles. Im just a little confused if I put motor to 1 piston tdc which valves can I check and then where do I have to move the crank next to check other valves? Thank you in advance for for help
look @4-17 (page 106 ) its pretty cut and dry on how to. in the FSM that is. but yes u check vales @ tdc and 1 turn out of tdc
Is there anyway you could tell me which valves to check when the crank is in a certain position my manual got lost when I moved or my wife threw it away so I wouldn't work on it anymore thanka
Buy a new service manual or find one online...
#1 cylinder at TDC check intake and exhuasts of #1
#2 at TDC check all of # 2 valves etc....
easiest most accurate way of doing them
