1 - 20 of 52 Posts
Hey guys, just wonder what would be good to design and 3D print. First project will be the Gauge pod.
What will you guys like to see?
I can also design and cut flat sheets of metal for cheap but I don't think there is any use for that.
I havent forggotten, currently in the process of relocating the gauges, then make a steering damper that doesnt use that big rod. Currently printing the gauge mount hole sizes. suggestions of where to place the gauges?
139053
139055
139054
139056
will be using this yellow steering damper then adapting it tot he piston thing steering damper in the center of the fork holder things/ handle bar
Discussion Starter · #9 ·
Ayy looking good. That's a MT-07 windscreen, i have a MT-09 windscreen coming also. Currently have the gauge cluster zip tide with a custom bracket, waiting on the MT-09 windscreen and the Sportsbar to come in before I design a mount. Next will be removing the fairings and making something for the radiator after the front end is done.
139125
Why fitting the MT-09 screen? Do you need more wind protection?
I think it already looks great with this screen :D
Nice job anyway, keep posting!
Discussion Starter · #11 · (Edited)
The 3D printed gauge bracket, can easily be modified for your needs. Yes it has slots for nuts for the bolts on the sides, it attaches to my windscreen. Amy suggestions for covering up the forks above the bottom fork triple clamp?
139189
Discussion Starter · #16 ·
139493
Steering damper compatible with sports bars coming soon™ the adapter is Resin printed with a mix of 75% engineering resin and 25% flexible resin. On previous pics you can see that i already installed a steering damper bracket that is not as strong
Just need to modify this that's already installed on the bike
Font Tool Material property Eyewear Auto part
Good or dumb idea? Either way it will be installed. Total price $150
2015 Versys handlebar upper clamp
You think it will fit if i use those two holes to make a cluster mount
... Only if there was a different gauge cluster that wasn't so ugly and shows fuel level
There's definitely a need for those of us who modify to mount the stock gauge somewhere else. Kudos to you for doing this!
I dont have a 3d printer and took the more expensive route and I used a Koso DB03r for exactly this reason. It has a fuel gauge, its much smaller than standard, Has most of what you need except for ABS and Fuel reserve light and has lots of other features the stock one doesnt have; i love mine.
Discussion Starter · #19 ·
I have looked into the koso gauge, i first need to install a connector (already bought two pairs) for the stock gauge that allows me to swap between the two. Going to need an oscilloscope to figure out the missing sensors and might have to creat a custom circuit .
Then I gotta finish up my 3d printed headlight mount and somehow make an appealing windscreen
What missing sensors ?
1 - 20 of 52 Posts
