1 - 2 of 2 Posts
Hi all, New here and have a question about replacing my instrument cluster.
I have a 2009 European ZX6r and I have a problem with the cluster ad need to replace is. I am wondering if get a used one in good condition off Ebay from the same year etc will I be able to just plug it in and away I go?
Also if I get a replacement with 10,000 miles on it for example will this be reset to my bike's actually mileage or stay at 10,000?
Any help would be greatly appreciated before I spend nearly $200 on a replacement (Like this one)
https://www.ebay.com/itm/09-12-KAWASAKI-NINJA-ZX6R-SPEEDO-TACH-GAUGES-DISPLAY-CLUSTER-SPEEDOMETER/222691401911?fits=Model:Ninja+ZX6R|Make:Kawasaki&hash=item33d97120b7:g:mDYAAOSwe51Z70EH
Thanks
Brian
Straight swapping clocks isn't an issue, you can plug it in and away you go... as for the mileage!!! you will have to edit the EEPROM chip inside the clock itself, depending on where you are you should be able to get someone to do it for you, or if your technically able, you can do it yourself
1 - 2 of 2 Posts
