1 - 2 of 2 Posts
I have a 2012 er6n its maintained very well. 20,000 miles all factory except for slip on. Riding for 10 min or so it dies oil light comes on and now fl light on when I try to start. It will run for 2s & die fl light on. Any ideas
Hey try to pull codes from the ECU by following this:
It's the exact same for the ER6, you can find the OBD connection under the rear seat and it will look similar to the one in the Video.
That will tell you where to start, if you can't get the codes for whatever reason I would start by checking cable connections to injectors making sure everything is plugged in.
If you still havent found the issue, it goes deeper, but if really is that bad there should be a code for it in the ECU.
1 - 2 of 2 Posts
