I’ve recently bought an er6n 2013 and my first ride I had a bit of a crash on the right hand side damaging the coolant bottle and the plastics. I’ve replaced the coolant bottle and plastics but when I went to test drive it it wouldn’t shift into any gear, the neutral light goes off when I shift into gear but it’s not letting me drive, I’ve tried shifting into first and second without the clutch expecting it to stall but it doesn’t and just idles and dies. I’m wondering if anyone would have any info whether it’s the clutch or the gearbox I could have issues with before I give it into a shop
· Moderator
Have you tried pushing the bike with the clutch lever released and the bike in 1st gear? Sometimes you just need to spin the transmission over for everything to fall into place.
I have I’ve pushed it while it was in gear leaving the clutch out slowly and not using the clutch with no luck, I thought I could’ve pinched the cable somehow aswell but that’s running freely up and down the tube
Sounds like the fall may have dislodged the selector mechanism behind the clutch so when you think its in gear it hasn't moved the Drum.
Possibly the Spring has popped off but that would also result in a very loose Gear Lever.
