Ninja 300, code 39 (ECU)Battery is good (12.7v) found no wiring issues, main fuse good. Gets power, starter Solinoid working properly. getting spark... all lights on IC working perfect, bike just continues to turn over but not crank. All lights on bike work properly. No other blown fuses.
** found the fuel pump is not turning on, I tested power and it was getting correct voltage and jumped power to the pump and pump worked fine **
Bad ECU or wiring issue? I have ohm out every wire and they all test good. Couldn’t find any bad connections. Unless I just missed something
Also, bike was running perfect, transported bike to new house and wouldn’t crank on the trailer when i arrived
