Hey so I just bought a used 2015 Ninja 650. Been running around a little bit and noticed that the rear brake pedal is bent. Looking for a replacement online. I'm curious whether the ZX6R brake pedal will work because that's what most of my search results are coming up with? As well as the Ninja 250 300 or even a ZX10 brake pedals? Or does it have to be specific for the Ninja 650?
I use a European parts website as they list which models the part is used on
If they are interchangeable then the part numbers would normally be the same. Sometimes the different number is because of unique paint or small changes as well
Here is the specific part, Id say zx6 and zx10 parts would be a long shot but it appears pedals from other ninja 650 years - from 2012-2016 will fit. Hope that helps ?
Discussion Starter #3 (Edited)
I was thinking those would all work because they were from the same generation. Just wondered if you guys knew of some aftermarket options or anything else. The dealership nearby me ordered a replacement OEM brake pedal for $68.80, should be here in 3-5 days. So maybe by that I can find a cheaper or better route to go. I will use that Parts number for future reference on other things. I appreciate that.
