$8,000
Located in Chicago area. Text with questions - Eric 847.243.7808
All photos here: 2019 Versys 650 LT - For Sale
Walkaround video here
2019 Kawasaki Versys LT with ABS
Stored in a temperature controlled garage
1,067 miles, first service performed with Kawasaki OEM oil and filter
Owner's manual and 2 keys included
Key-matched and color-matched OEM saddlebags
OEM Kawasaki hand guards
Excellent condition - only flaws:
1. A tiny paint chip about the size of a size 12 font period that is underneath the tank clear bra.
2. Small scuff on left saddlebag from being moved a bit while on the garage floor.
3. Normal wear on windscreen
I have receipts for everything. All accessories total $1,828.00
Brand new Michelin Road 5 tires, installed March 2021 - $368.00
Right-angle valve stems - $13.00
Shoodaben ECU flash - $278.00 - read more here: https://sites.google.com/site/shoodabenengineering/home/versys-650-ecu-flash
Annitori Pro V2 quickshifter with Bluetooth connectivity (SO MUCH FUN) - $220.00
Adjustable windscreen spoiler - $38.00
T-Rex Racing luggage guards - $170.00
Rear tire hugger - $32.00
16T countershaft sprocket for better highway riding - $16.00
XPEL Ultimate clear tank protection, professionally installed - $80.00
Koso heated grips with integrated 5-level controller, wired to relay - $115.00
Dash-mounted QC 3.0 USB ports and voltmeter - $20.00
VLEDs 6" white LED bars mounted in lower vents - $75.00
VLEDs 6" red LED bar as auxiliary brake light - $40.00
VLEDs 3" amber LED bars mounted inside stock signals - $100.00
Amber fog lights mounted to frame sliders, custom waterproof switch mounted in switch control with LED indicator - $70.00
LED flasher relay - $11.00
VLEDs pure white license plate LED - $14.00
Marco Tornado air horn, separated (LOUD) and wired to relay - $50.00
Black brake and clutch levers - $31.00
Front fender extender - $30.00
Rear spools - $20.00
Suzuki rear axle nut (no more castle nut/cotter pin) - $20.00
Aluminum Versys kickstand pad - $18.00
139151
