1 - 2 of 2 Posts
The other day I did an oil change on my bike, and took it out for a lil ride to make sure everything was in working order, but I went to shift and my quick shifter won’t work. At first it was just as stiff as a rock and would not move unless bent. Now it is still the same but randomly it will work for 1 and I don’t know which one it’ll work. Just hoping someone will have a answer for me.
Moderator
Sounds to me like the switch is bad or not connected. Unplug it and put an ohm meter between the two wires coming from the quick shifter. Press the shift lever and see if the switch is closing & opening.
1 - 2 of 2 Posts
