2nd gear?
850 Views 6 Replies 3 Participants Last post by  bs121583
synch your carbs
that's it? what could possibly cause a bike go rich without doing anything to the carbs? maybe i got my air filter dirtier? maybe i kinked an air suction hose?
btw, how fast am i suppose to be going in 2nd at 11k?
Originally posted by bs121583
synch your carbs
I would make sure I have no intake leaks along with what bs121583 said and synch your carbs.
Kelsey
just wondering, how fast should the bike be going around 11k in 2nd gear, for some reason, i remember going like 90 or something :)
now it's around 70mph...also, if any of you read in my previous post, i pulled apart my bike, now when i put it back together, it seems to be running rich. But i didn't change a damn thing on the bike, basically just got to the valves, measured the clearance and shims and put it back together. When idling, if i rev it, the tach hangs a little bit then drops. That's the sign of it being rich right? anyways, how can this happen when i didn't do any modifications? also, it idles like crap now too...just standing still, it would sit at around 1.5k for like 5 seconds, drop to like 900 for a second then back upto 1.5k for another 5 seconds.
bleh!!! is all i got to say
See less See more
yeah check for leaks at the vacuum lines.. and about the 2nd gear thing... i dont think 90 sounds right i think 70 is where mine reads
what does this symptom mean?
when i go for a nice 10minute ride, then park it, then restart it. the bike jumps to 3k rpm for like 2 seconds, then drops down between 1.5k and 1k, which as of right now, normal warmed up idle
i would due the things that have been listed and see if that clears up your problem then you will know what was wrong...
