1 - 10 of 10 Posts
hey guy's i'm just trying to find out some info. i have an 03 636 with a blown motor. dont ask long story lol. i also have a motor from an 06 636.
i do have the service manuls for both bikes. so what i would like to ask is if any one might know if the motor mounts for the 03 and the 06 would match up??
if any one has some info on this please get back to me
true that. i should be picking up the 06 motor this weekend. i was kinda hoping that it would be something easy to do and not have to make any custom parts to get that motor to fit.
well looks like your going to be the 1st to find on here.
also what about your wire harness and ecu?
you changing them as well or going to try and run the 03/04 on the 05/06 motor?
if the motor bolts in that is what i am curious about...will watch and see what you do...
good luck
JD
g zero,
Did you find out if this will work? my 03 6rr motor is blown, I think and I am trying to decide on rebuild or replace.
ANY help or suggestions would be appreciated.
thanx
screw3 the new 2007 motor, just do a little top end freshing on your 636, as it will make Power.
Well, considering the new one is light and faster and has alot of fix, doing some top end freshening wont accomplish nearly as much
1 - 10 of 10 Posts
