1 - 2 of 2 Posts
Noticed radiator fan not working and my 2003 650 Prairie overheated. Disconnected wire from radiator bulb and connected a wire from the + side of battery and fan works. Fuse under seat is good. Can radiator bulb be checked? Are there other areas that might be causing the fan not to run?
Not too familiar with this vehicle but m pretty sure it would be...
Fan Relay (? electrical location, probably somewhere near the battery)
or
Temp Sensor (2710A) (follow the wire to the relay)
or possible some wiring in between
You know the fan is working and the battery, so those other two items are "in between".
Good Luck Link
1 - 2 of 2 Posts
