1 - 9 of 9 Posts
Ok, I've searched and read several threads about either raising the rear or raising the forks to compensate for a 70 front.
I recently put Pilot Powers on, with a 70 front.
I haven't adjusted, and find that the ride now is a lot nicer than before. Has anyone who put a 70 on front noticed anything negative so far?
Also, can anyone give feedback on the 70 front leaving as is, AND adjusting to compensate?
Thanks all.
Every manufacturer has different diameters in the same profile tire. If you change from one to the other, a 165 may actually be bigger than a 170. Don't worry about it. If it seems to turn slow ( and give it a month ) then you can change the suspension.
the only way you know is to actually measure the circumference of the tire.
I too went from a 65 series BT-014 to a 70 series Pilot Power and I feel a noticeable inprovement. I had already raised the forks up in the triple clapm prior to the tire swap but haven't adjusted after. I most likely won't.
got a 70 qualifier on my 04 and I took it to the track 2 days after I mounted it. NO PROBLEMS. Feels more stable in a straight line... maybe a little slow in the turn but nothing to worry about.
I guess I could have added a little bit to my original post.
I actually find the bike turns in quicker, and feels more comfortable just riding. However, that may be due to new tires? I will ride it out and then try changing the forks or raising the rear.
Thanks everyone for the input.
1 - 9 of 9 Posts
