well, if you're interested in alternatives to interchanging fairings, you could try making it into a naked bike. I have the same bike and that's what I'm doing with mine. without fairings you can mount the front signals onto the fairing mounts towards the bottom of the frame, get a headless screw with the same thread and you should be able to switch it out with the original attachment for the signals so they'll mount closer in and not drag. For the headlight you can rig a bar across the front fairing mounts by the instruments and bolt some round bottom mount headlights to it, then you just gotta figure out the back, I still used the rear fairing just to make mounting easy, But i'm sure you can figure something out. If you don't like the naked bike look, check into zx600's up through 95, they're pretty similar, so you may be able to interchange parts, I haven't tried, but that's your best bet, pre-88 was a bit different model and after 95 they changed a lot again.
