Hey All, just joined the forums. Ive had my 9 for 3 years now and am very happy with it until now. I just went to have a valve adjustment done and found out that I need about $2000 in parts to rebuild the top end with new cams and rocker arms and such. What other years engines might fit my bike ? My research says 94 to 97 is all good.. what about a 98 ? I found a 98 zx9 motor. Will it fit or will there be alot of messing with connectors to swap ?THanks for all your input !
''Tranny took a shit in my 34k mile engine its been sitting in my garage apart for 6 months and need it gone. Tranny needed a lot of work and found a low mileage engine for less then it would have cost to fix the tranny. I have everything that I removed to split the cases except the tranny, let me know if you need anything. Engine ran really strong and the main bearing look good.
Engine had the oil changed every 2k and didn't leak or smoke or use any oil.''
Out of a 99ZX9
I posted this fs and not sure where it got moved to but here is what I have not sure if it will fit yours or not.
