21 - 39 of 39 Posts
Discussion Starter #22 (Edited)
Bump... updated list, prices below.
Motor/trans runs shifts good - 400.00
Frame/straight clean - 200.00
Subframe - 50.00
Rear undertail/battery tray - 40.00*
Swingarm - 40.00
Rear shock with linkage - 40.00
Wheels - 200.00
Front axel with spacers - 10.00
Rear axel with spacers - 10.00
Left/right passagner brackets/pegs - 40.00
Upper tripple tree with ignition - 50.00
Lower tripple tree - 40.00
Radiator - 100.00
Lower radiator stay bracket - 40.00
Speedo instrument gauge - 100.00
Upper fairing stay gauge/bracket - 40.00
Upper mirror stay bracket - 20.00
Fuel pump - 50.00
Ram air tubes - 20.00
Airbox - 20.00
K&N air filter - 20.00
Chain - 20.00
Rear sprocket with hub - 20.00
Front fender - 40.00
Wiring harness - 50.00
Ecu/cdi - 50.00
Relay junction fuse box - 20.00
Rectifier - 20.00
Tail light - 20.00
Turn signal flasher relay - 10.00
Coil packs "set of four" - 20.00
Ignition coil wiring harness - 10.00
Horn - 5.00
Throttle cables with cable housing - 20.00
Miscellaneous bolts for various parts
Discussion Starter #23
Motor, wiring harness, coil packs, ignition coil wiring harness... Sold
Sent from my SCH-I545 using Tapatalk
Discussion Starter #30
Left/right passagner brackets pegs, rear sprocket/hub... Sold
Discussion Starter #32
Bump. Updated list and prices below
Swingarm - 50.00
Rear wheel - 100.00
Radiator - 100.00
Fuel pump relay - 20.00
Airbox - 20.00
Ecu/cdi - 50.00
Rectifier - 20.00
Tail light - 20.00
Horn - 5.00
Miscellaneous bolts for various parts - make offer
I am working on a salvaged 07 zzr600.
May be interested in
Upper tripple tree with ignition - 50.00 if it has keys to go with it.
Rear undertail/battery tray - 40.00 if its not cut up or damaged
Would need to be shipped to NY 14467.
Let me know.
Thanks,
David
Discussion Starter #34
Let me know.
Thanks,
David
Pm sent
Discussion Starter #35
Bump...
Swingarm - 50.00
Rear wheel - 100.00
Radiator - 100.00
Fuel pump - 50.00
Airbox - 20.00
Ecu/cdi - 50.00
Fuse box - 20.00
Rectifier - 20.00
Tail light - 20.00
Horn - 5.00
21 - 39 of 39 Posts
