1 - 20 of 48 Posts
Hey guys im parting out a low mileage 07 zzr600. Here is list of parts that i have left up for grabs paypal is welcome.
Motor/trans runs shifts good - $400
Carburetor/stage 1 jet kit - $100
Header/mid pipe - $50
Frame/clean with title - $400
Frame/clean with out title - $200
Forks - $100
Subframe - $50
Rear undertail - $50
Swingarm - $50
Rear shock - $40
Wheels/rotors - $300
Front axel - $10
Rear axel - $10
Passagner brackets/pegs - $40
Upper tripple tree - $40
Lower tripple tree - $40
Radiator - $80
Headlight - $100
Speedometer - $80
Fuel pump - $50
Ram air screen - $20
Ram air duct covers - $40
Ram air tubes - $20
Right side ram air cover - $10
Airbox - $10
K&N air filter - $10
Front calipers with pads - $40
Rear caliper with pads - $20
Front/rear sprockets with chain - $40
Front fender - $20
Wiring harness - $50
Ecu - $50
Fuse box - $20
Rectifier - $20
Starter - $40
Turn signal relay - $5
Coil packs - $20
Ignition coil wiring harness - $10
Choke cable - $10
Throttle cables with housing - $10
Speedo sensor - $10
Sidestand - $10
Clutch lever perch - $10
Sold...
Clipons
Clipon switches
Front mc
Rear mc
Driver seat
Clutch cable
Sent from my SCH-I545 using Tapatalk
hi ZX Racer,
I'm interested in the header/mid-pipe and was wondering if that fits on a 2004 ZZR 600, I'll do some research but perhaps you already know ?
thanks !
Robert
hi ZX Racer,
thanks !
Robert
Yes it will fit 98-02 zx6 and all year zzr600 parts interchange.
Thanks for the answer ZX Racer !
I was wondering if the following would be acceptable:
I can send you a money order and you ship the part
only after you are satisfied payment is good and has cleared.
I'm in NJ so shipping would be to zip code 08873
Thanks again for your reply,
Robert
Discussion Starter #7
Robert
Pm sent
hi ZX Racer,
Just wanted to give you an update - I did mail the money order on the 23rd so you should receive it soon.
also I now know why you didn't receive my previous PM - apparently because I'm new to this forum and have less
than 15 posts it's not allowing me to PM you - same reason I wasn't able to send you one just now to give you the update. apologies to all who can view this (and see it as crap ) but it's beyond my control. Guess on the bright side, I'm closer to that magic count of 15 (posts) and soon will be able to use PM as intended. :) take care all and hope everyone had a nice Xmas !
Robert
Discussion Starter #12
hi ZX Racer,
Robert
Hey Robert header, midpipe is on its way lmk when u receive it thanks.
Any chance you have the rear fender.? The black plastic under the rear seat ? I bought an 01 6r and PO cut it up to look cool I guess.
1 - 20 of 48 Posts
