Hi all,
it took awhile but i've finally managed to score a 2nd hand twin headlight.
Now..... how do I connect the wiring etc??? Will it connect straight into my existing wiring/plug or is'nt it that simple????
I think i've read that its better to get the wiring from a 2000 model and use that....
would appreciate any help/advice
thanks in advance
Row
You have to be careful here. When they went to a dual headlight they changed over to a relay system to take the current out of the hand switch. If you just splice the leads you are going to be pulling double the power through the switch and run the risk of melting your hand controls. I would very strongly recommend you get set of automotive relays, one for the highs, one for the lows.
