1 - 18 of 18 Posts
After 2011 650r FULL Wiring Diagram. I have the Kawasaki Ninja 650R Service Manual.pdf from the net but the text on the wire diagrams is not clear. low res.
Any one got a high res version or a colored version? Thanks.
138439
OK.
First picture leave the wires cut but pop some insulation around them so they don't Earth out accidentally.
Second picture, That is a multi point Earth connector (Often they do the same for Positive wires on the same circuit) Leave as is.
Third picture, That is another multi Earth connector just thicker gauge wires encapsulated, Leave as is.
I know in Australia If it’s a LAMS bike(restricted model) the cut wires on the diagnostic connector are actually how they tell the ECU to impose a lower rev limit. They’re usually a loop. To cut the loop you’re de-restricting the bike.
That's why I told him to leave them cut.
I believe its also a requirement in Germany.
In the UK We leave it with the oem cap on when restricting A2 Bikes, I have a draw full of caps with the wires linked 😀
Discussion Starter #14
I'm from New Zealand. :) and the engine is not going back in a bike but a offroader. :) To replace the old vrf400 that last owner killed.
138458
Discussion Starter #15
Wish I had a draw full of linked ones. :( guess I need to solder it together to unlock the full power of this beast.
1 - 18 of 18 Posts
