Hiking boots for the road, anyone? Alpinestars has you covered with the CR-4 Gore-Tex XCR Boots. These waterproof motorcycle boots are ideal for any rider that likes to ride his bike to distant places and then, hike further off the beaten path. They’re also exceptionally comfortable for work around town and the Gore-Tex waterproof membrane means your feet will stay dry too. Fabricated with a combination of polyurethane-coated leather, suede and textile panels, the CR-4’s look more like hiking boots than riding boots. But, that doesn’t mean protection isn’t built in – two shanks run the length of the sole and extra foam padding has been inserted around the ankles. Plus, a PU-coated leather patch resides just above the toes so shifting won’t wear into them at all. Inside, a breathable mesh liner greets the foot and reinforcements are provided for the toe and heel areas for extra protection. The feet rest atop a comfortable, anatomically-shaped footbed for comfort. As you can see, the spec sheet reads a lot like a high end hiking boot, only better!
You can get more information about the CR-4 boots, and any other Alpinestars products on our website, or by getting in touch with MIKE. Contact him through this forum or by calling 866.931.6644 ext. 804. Is email more convenient? Feel free to send those to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away!
Alpinestars CR-4 Gore-Tex XCR boots are available in Silver/Anthracite (shown), Anthracite/Red and, of course, Black.
A grippy outsole is contoured for surefootedness in wet or drive conditions. Two separate shanks are used within the base for extra protection while still permitting a comfortable range of movement.
Strong metal eyelets and two hooks at the top allow you to easily tension your laces.
To carry the Gore-Tex name, the equipment in question must be certified by Gore-Tex labs to function as advertised. This assures that the end user receives exactly what’s expected of the equipment in question.
Both toes are covered by PU-impregnated leather that’s designed to withstand years of shifting without wearing through.
