Annoying Vibration Under Acceleration....
  • Handlebar Clip-On
    Votes: 0 0.0%
  • Motor Shimmed Incorrectly
    Votes: 0 0.0%
  • Motor Grounding Out On Frame
    Votes: 0 0.0%
  • Other...(Please Explain Opinions)
    Votes: 0 0.0%
I have an '06 636, and I went down on the right side. I rebuilt my motor due to an engine knock (long story). I grinded my whole bar end off and it went into my actual right handle bar clip-on. Ever since this incident has happened, I have had an annoying violent vibration in the handle bars when I accelerate or just cruise under power slightly. When I pull in the clutch riding down the road the vibration goes away. The dealership says the handlebars are balanced and weighted and since I shaved mine down pretty good, this is whats causing the vibration. I think thats BS because when I have the bike sitting there running at idle I can rev it up a little bit and it will still vibrate through the frame and handlebars. Also, when I ride, I can let go of the handlebars and it will steer straight so that kinda rules out the forks being bent...
Question is...Is my vibration from the handlebar being shaved off; my motor wasnt shimmed correctly in sequence when put back in the frame; or is the motor grounding out on my frame some place?
