1 - 20 of 30 Posts
I just picked up my swingarm spool sliders today and installed them, the left side slider has a longer bolt and spacer, why is this? I think I'm going to remove the spacer and cut down the bolt.
Generally they don't work... they'll just break off the whole bung from the swingarm when they hit the ground.
don't you need them to jack up your bike for the most part?
Originally posted by slam150
well, if they save beating up the swingarm then why not getem. i got mine and guarantee they will work.
The mount will break off after it hits the ground. Then it will scratch up the swing arm. Oh yeah if it was a good spot weld it will rip a little hole in the swing arm...
If your going to use the slider to pick up the bike with a stand make sure you install the spacer and the longer bolt it's made like that for a reason....
Discussion Starter #7
Anyone noticed any reduced lean angle? That was another thing the guy at the shop brought up, he said most people just end up tossing them because you can 't lean the bike over as far.
i think if you're doing tracks, then you'd go with smaller spools or no spools. however, thats a pretty far lean.
i haven't noticed any reduced lean angle, but then again i've yet to hit a track. as far as your spacing, i haven't had any prob'z with mine, you might have your incorr'. installed. i'd use 'em!
I made a set out of Delrin and I had to make them differently. The swingarm is not symmetric and the threaded bungs are also welded in different places. The spacer and longer bolt are for the side that the bungs are farther underneath the swingarm. On my '01 that was the drivers side (left as sitting on the bike).
Regarding lean angle, I think my clip-ons would hit before the spool/sliders. I guess it depends on how long they are and what diameter.
unless they are absurdly long i can't see that happening, race bikes have spools, why don't they hit to early?
u gotta be kidding me? draggin spools? wouldn't your pegs hit first
I believe it's the peg in the video. Sweet video! I wish I could go around a turn at 120 breaking the rear wheel lose.
dragged my knee just fine at the track with the spools..
and i crashed 2x with them and they worked great, swingarm and rim came out unscathed
1 - 20 of 30 Posts
